Is it possible to create a user-defined type which can have parent-child structure?
TS_10782016
Hi, I'm wondering if it is possible to define a new subtype of WTDocument which can have both WTPart and WTDocument as its child? Something like a parent WTDocument Order A, and it has child Order A-1, Order A-2, which both contain a series of WTParts.
I'm using Windchill 12.1
Thank you!
1 ACCEPTED SOLUTION
Hi @TS_10782016
All useful info is on a PTC Knowledge base
CS156972 - Windchill PLM - Configurable Links
PetrH
4 REPLIES 4
Hari_Vara
(To:TS_10782016)
I would fulfil your requirement by
a. Define that subtype of WTDocument , say WTDOCA
b. using "Configurable Links", I would define a new type of Link called "Order Info", This will come as a tab in WT Doc and WTPart.
c. Define Relationship constraint saying that WTDOCA can have child type WTDOCA and WTPart
It is also possible to edit the OOTB WTDocument's relationship constraint to achieve the steps b and c above, However I would refrain from playing around the OOTB relationships.
Best Regards
Hari
TS_10782016
(To:Hari_Vara)
Hi Hari,
Thank you for your reply. Could you please tell me how to define new Configurable Links? I only found this document, but there is no information about creation of Configurable Links.
Using Configurable Links (ptc.com)
Thank you!
Hari_Vara
(To:TS_10782016)
Please check in "Windchill Customizer's guide".
Hi @TS_10782016
PetrH
