Hello all,
I'm currently writing a custom JSP to summarise changes resulting from a Change Notice, I've managed to pull all the required data into the report except for Assigned Usage Expression (e.g. 'COLOUR= "GREEN"), which I'm struggling to get, does anyone know of an API method to retrieve this?
I've tried:
CS384380 states that there's no supported API to achieve this, however that's not to say there isn't one available. Worst case, I could always build the expression through QuerySpec, but it feels like reinventing the wheel, if anyone knows of a method for getting the expression then it would be greatly appreciated.
Graham
Hi @GrahamV
It is not so easy to find the correct API
OptionHelper.service.getAllChoices(child, optionSet);
here you can see the API how to get options from your result optionset with wtpart. Also try to use the Usage link as a input
OptionSet optionSet = result1.getOptionSet();
WTList[] choices = OptionHelper.service.getAllChoices(child, optionSet);
Here is my working code
You can create reference from WTPart or UsageLink and combinate it.
ObjectReference ref1 = ObjectReference.newObjectReference(wtpLink); WTPartUsageLink
ObjectReference ref2 = ObjectReference.newObjectReference(subpart); WTPart
OptionSetDelegateResult result1 = OptionHelper.service.getAssignedOptionSet(ref1, ref2);
WTList[] choices = OptionHelper.service.getAllChoices(wtpLink, optionSet); // result for specific usageLink
PetrH
Hi @GrahamV
Where is the expression assigned? WTpart, UsageLink? difference place ?
Here are apis that can be used
//with WTReference
OptionHelper.service.getAssignedOptionSet(WTReference var0,WTReference var1);
//with colletion
OptionHelper.service.getAssignedOptionSets(WTColletion var1);
PetrH
Hi Petr,
I'm trying to retrieve the Assign Usage Exapression (i.e. the expression associated to WTPartUsageLink), though I suspect the same method will also work for other Expressionable objects like WTParts.
The methods you listed appear to get the Assigned Option Set rather than the Assigned Usage Expression, so I don't think that's what I'm after, it may come in useful though.
Graham
Hi @GrahamV
What Assigned Usage expression are you talking about?
The Assigned Usage Expressions are from the OptionsSets and the API retrieve it as you can see it in the Uses tab in the Structure.
If you use WTReference where you put usage link you will get what is in that usage link assigned.
Or you can put first reference as a parent and second reference as a child WTPart and you would get again the Assigned Usage Expressions
PetrH
Hi Petr,
Yes your image shows exactly what I'm trying to extract, however I can't see how the OptionHelper methods can retrieve this, as it returns an Assigned Option Set not an Assigned Usage Expression, I don't believe you can navigate between these objects (or rather you can't navigate from an Option Set to an assigned Choice, since expressions are really just a set of assigned choices).
I tried your suggestions anyway...
//Using WTReference method
WTPart parent = usageLink.getUsedBy();
WTPartMaster child = usageLink.getUses();
ObjectReference ref1 = ObjectReference.newObjectReference (parent);
ObjectReference ref2 = ObjectReference.newObjectReference (child);
OptionSetDelegateResult result1 = OptionHelper.service.getAssignedOptionSet(ref1,ref2);
String optionSetName = optionSet.getName();
This returned an Option Set, I couldn't see any methods to get to an expression or choice.
//Using WTCollection method
WTArrayList collection = new WTArrayList();
collection.add(usageLink);
OptionSetDelegateResult result2 = OptionHelper.service.getAssignedOptionSets(collection);
OptionSet optionSet2 = result1.getOptionSet();
String optionSetName2 = optionSet.getName();
This one returned null, not sure if I did something wrong or maybe WTPartUsageLinks just don't get assigned Option Sets (quite possible, as the Option Set assigned to the parent WTPart is what dictates the available options).
Open to any suggestions, or if you have any example code that pulls Assigned Usage Expressions that would be most helpful.
Graham
Hi @GrahamV
PetrH
Hi Petr,
Got round to trying your suggestion, this succefully retrieved the choices, many thanks!
I had to do some more work to merge the WTLists into an expression string, couldn't find any OOTB methods to do this but I need something custom anyway (in my use case I need to be able to merge two expressions together), here's what I came up with...
public static String getExpression(ExpressionAssignable expressionAssignable) {
try {
//Get the Option Set
WTPartUsageLink usageLink = (WTPartUsageLink) expressionAssignable;
ObjectReference parentRef = ObjectReference.newObjectReference (parent);
ObjectReference childRef = ObjectReference.newObjectReference (child);
OptionSetDelegateResult result = OptionHelper.service.getAssignedOptionSet(parentRef,childRef);
OptionSet optionSet = result.getOptionSet();
//Get the Choices
WTList[] allChoices = OptionHelper.service.getAllChoices(usageLink, optionSet);
WTList includedChoices = allChoices[0]; //Included Choices
WTList excludedChoices = allChoices[1]; //Excluded Choices
//Generate the expression string
ArrayList<String> expressionArray = new ArrayList<>();
expressionArray.addAll(getExpressionArray(includedChoices, " = "));
expressionArray.addAll(getExpressionArray(excludedChoices, " ≠ "));
Collections.sort(expressionArray);
String expression = String.join("; ", expressionArray);
return expression;
} catch (Exception e) {
return "Error";
private static ArrayList<String> getExpressionArray(WTList choices, String includeExclude) throws WTException {
//Add all the choices to a map to allow grouping by option and = / ≠
Map<String, ArrayList<String>> map = new TreeMap<String, ArrayList<String>>();
for (int i = 0; i < choices.size(); i++) {
Object object = choices.get(i);
if (object instanceof ObjectReference) {
ObjectReference objectReference = (ObjectReference) object;
Object choiceObject = objectReference.getObject();
if (choiceObject instanceof Choice) {
Choice choice = (Choice) choiceObject;
ChoiceMaster choiceMaster = (ChoiceMaster) choice.getMaster();
String choiceMasterName = choiceMaster.getName();
OptionMaster optionMaster = (OptionMaster) OptionHelper.service.getOptionForChoice(choice).getMaster();
String optionMasterName = optionMaster.getName();
ArrayList<String> group = map.get(optionMasterName + includeExclude);
if (group == null) {
group = new ArrayList<String>();
map.put(optionMasterName + includeExclude, group);
group.add(choiceMasterName);
Collections.sort(group);
//Generate an arrayList of option expression strings
ArrayList<String> expressionArrayList = new ArrayList<String>();
for (Map.Entry<String, ArrayList<String>> entry : map.entrySet()) {
ArrayList<String> choicesArrayList = entry.getValue();
String optionExpression = entry.getKey() + String.join(", ", choicesArrayList);
expressionArrayList.add(optionExpression);
return expressionArrayList;
This seems to work well 🙂
