Programmatically "Disable Check out on the fly" preference
gfontana
8-Gravel
Hello everyone,
 i need to programmatically set the "Disable Check out on the fly" preference.
I have found PreferenceHelper class used to retrieve the value, any correspondents class to set the value ?.
Thank you
2 REPLIES 2
Florent
(To:gfontana)
Take a look at the methods (depending on the type of the preference):
wt.preference.PreferenceHelper.service.setValue(...)
Florent ROUSSEL
www.4cad.ca
Hi Florent,
classical Columbus egg.
I will let you know when i try.
Thank you
