Re: How to retrieve Quantity attribute for WTPart Structure?
JM_10276355
As per this thread - same issue
Hi rkumar,
I too have the similar kind of need, where I need to fetch all the bom structure and get the custom attributes values that or on Usage link.
Is there any way if i can get both the Link and wtpart or wtpart master? Let me know
Hi @JM_10276355
the ibah is object that represents WTPart or EPMDocument, or other types.
So put there the object for example WTPart.
IBAHolder ibaHolder = IBAValueHelper.service.refreshAttributeContainer((IBAHolder) ibah, null, null, null);
DefaultAttributeContainer dac = (DefaultAttributeContainer) ibaHolder.getAttributeContainer();
StringBuilder values = new StringBuilder(); // it will be filled with values
if (dac != null)
AbstractValueView[] abstrAttrib = dac.getAttributeValues();
// search for atribute name
for (int i = 0; i < abstrAttrib .length; i++)
AttributeDefDefaultView attrDef = abstrAttrib [i].getDefinition();
String atrName = attrDef.getName();
if (atrName.equals(ibaParam)) // ibaParam is an internal name of attribute
values.append(retValue.length() == 0 ? "" : "@");
values.append(getValueView(avv[i]));// if attribute has more values
PetrH
3 REPLIES 3
Hi @JM_10276355
you can use something linke following code.
It gives you UsageLink and  child WTPart
WTPart wtp = (WTPart) wtpObject; // source Parent from another search function
ConfigSpec localConfigSpec = ConfigHelper.service.getConfigSpecFor(wtp);
QueryResult qr = WTPartHelper.service.getUsesWTParts(wtp, localConfigSpec);
if (qr.size() != 0)
while (qr.hasMoreElements())
Persistable persistables[] = (Persistable[]) qr.nextElement();
WTPart subpart = null;
if (persistables[1] instanceof WTPart) // second place in array is WTPart
subpart = (WTPart) persistables[1];
WTPartUsageLink wtpLink = null;
if (persistables[0] instanceof WTPartUsageLink)
wtpLink = (WTPartUsageLink) persistables[0]; // first place in array is WTPartUsageLink
IBA attributes could be get by
DefaultAttributeContainer  dac contains all IBA attributes of the object so you have to search which IBA attribute name you really want.
Hope this can help
PetrH
Hi @HelesicPetr
That was a quick input, thanks !! I also wanted to know how can we get the IBA from the WTPart we fetched from the above code, I mean to say where to pass the WTPart object so that IBA is defined on the WTPart which is to be retrieved.
Hi @JM_10276355
if (dac != null)
PetrH
