We are happy to announce the new Windchill Customization board! Learn more.
Reference Type in custom Table
MV_10441462
Hi All @HelesicPetr
I have a custom table(in a wizard popup by a custom action) which collects all the required dependents of the main EPM and lists them. In the table, I need to have a new column to display the Reference Type between  main EPM doc and the dependent EPM doc.
I tried data utility but I'm not able to get the main EPM doc into data utility as it's called only for each dependent doc.
My requirement is to have a column for Reference Type where each component(row) displays their reference with the main epm Doc as shown in the attached pic.
Any idea or workaround?
See https://www.ptc.com/en/support/article/CS344421
You have not shown your existing code for your datautility however using the ModelContext parameter will get what you need I believe:
Object rmbObject = mc.getNmCommandBean().getActionOid().getRefObject();// the originally selected object
Thank you @RandyJones . Do you know how to get the Reference Type value to my custom table. I have two EPMs with CCP Reference Type, I want to have the same column in my custom table.
You can use the EPMMemberLink method getDepType
int depType = epmMemberLink.getDepType();
Refer to this for what the types are:
https://support.ptc.com/help//wnc/r12.0.2.0/en/index.html?_gl=1*uofyig*_ga*MjAxNjMxMzc5My4xNjk1ODMwNTM1*_ga_CBN5QVB9VJ*MTcwODYyMDA1MC45NTcuMS4xNzA4NjI0NjAyLjAuMC4w#page/Windchill_Help_Center/ProEWCIntegCustInternalRelDisplayConfig.html
Thanks again @RandyJones . But for CCP, I'm getting the depType valeue as-2013. I have CATIA V5 reference.
We don't use CATIA here.
You might find a reference similar to the Creo Parametric one with some searching or just reverse engineer it.
