We are happy to announce the new Windchill Customization board! Learn more.
Rest Service in Windchill
Sha11
I need to create a Rest service where it can be invoked by an external system. I have achieved the same using Soap Web Services but not with Rest. Please provide your inputs on how to implement the same.
Thanks in advance.
Sha
2 REPLIES 2
Ajit_Kulkarni
(To:Sha11)
Hi Sha,
All you need to do is make one rest entry like below in your rest.properties.xconf. Even you can have custom xconf with target as rest.properties. I found one at location Windchill\codebase\com\ptc\windchill\uwgm\rest\xconf but there are more in Windchill.
You also need to have a java class file in codebase.
You can follow article https://support.ptc.com/help/windchill/whc/whc_en/index.html#page/Windchill_Help_Center/NewandChanged_REST_Odata.html , https://support.ptc.com/help/windchill_rest_services/r1.6/en/index.html#page/windchill_rest_services%2FWCCG_landing_page_HC.html%23
to write the java code.
Hope this helps!!
Regards
Ajit
@Ajit_Kulkarni - Thank you for the information. I will check them out.
