Windchill customization, copy checkin comment to clipboard
Mat
Hi there,
the default behavior of windchill is, that if somethings goes wrong during checkin process, the checkin comment is lost.
So I tweaked  <Windchill-installation>\codebase\templates\uwgm\cadx\checkin\checkintables.js a little to make a copy of the comment to a new window like:
var comment_window = window.open();
comment_window.document.writeln(comment);
(I intentionally left all code out, which "prettifies" the new window)
  works great!
Now I want to copy the comment directly to the clipboard.
But when I try this
// copy comment to clipboard
		navigator.clipboard.writeText(comment)
		.then(() => {
		        alert("successfully copied: " + comment);
		  .catch(() => {
			alert("something went wrong");
 I get the error under Creo 8.0.6.0, "checkintables.js Uncaught TypeError: Cannot read properties of undefined (reading 'then')"
What am I doing wrong?
1 ACCEPTED SOLUTION
Mat
(To:Mat)
Ok, I think I found the solution
There is an article at w3docs.com about that.
https://www.w3docs.com/snippets/javascript/how-to-copy-the-text-to-the-clipboard-with-javascript.html
The third and last method works within Creo's embedded browser.
copyTextToClipboard(comment);
async function copyTextToClipboard(text) {
	try {
	  await navigator.clipboard.writeText(text);
	  console.log("Text copied to clipboard " + text);
	} catch(err) {
	  console.log('Error in copying text: ', err);
1 REPLY 1
Mat
(To:Mat)
	try {
	} catch(err) {
