Find all projects with (certain) attributes
We have several triggers that depend on member and/or project attributes (mail notification at checkin,...).
While the member attributes can be shown in a column in the GUI, the project attributes are invisible and can only be shown for a single project via project information.
The member attributes can also be found via commandline
si viewproject --fields=memberarchive,attributes --filter=attribute:<attrname>
but unfortunately, this does not work on project attributes.
We can list a project (with its attributes) via
si projectinfo --attributes
but projectinfo has no --fields and no --filter parameter and does not work recursive (for subprojects), so there is always only one project listed.
So the idea is to either
- have the project attributes be shown in the attributes column in the GUI
or
- add/extend the commandline so that project attributes can be found recursively and with filters.
2 Comments
awalsh
This is also problem with other subproject information (shared location, devpaths, labels, etc). The only way to see subproject information is projectinfo which has to be run one by one on all the subprojects, which is very annoying to do.
Siddharth
9-Granite
