Using the environment variable In the custom menu
Zeiad-Alkassem
Hello community,
In the custom menu , i want to use the environment variable %JAVA_HOME% may also to be use lax.nl.env.path variable. Could you please tell me How to call that from the "Customize User Button" windows?
Windchill RV&S 12.3.1
Any tips well be very welcome
Regards
Zeiad
1 ACCEPTED SOLUTION
Hi Zeiad,
Environment variable cannot be used in "Customize User Button".
You can refer to CS175170 for the details.
Ivy
4 REPLIES 4
Hi Zeiad,
Ivy
Hi @IvyZhuang
Thanks for your reply.
I was hoping that we could use .
Regards
Zeiad
Hi Zeiad,
I am using this script behind a custom command ("wscript runReport.vbs")
runReport.vbs:
Set WshShell = CreateObject("WScript.Shell")
cmds=WshShell.RUN("im runreport --hostname=%MKSSI_HOST% --user=%MKSSI_USER% --port=%MKSSI_PORT% --issues=%MKSSI_ISSUE0% --param=username=%MKSSI_USER% -g """&WScript.Arguments(0)&"""", 0, False)
Set WshShell = Nothing
And yes, I  am using environment variables.
Does this help somehow?
Hi @VolkerEckardt ,
Thanks for your reply and sorry for my late response.
Of course it will be useful, AS always your ideas 😉.
Regards
Zeiad
