we write this xml in info engine.
<%@page language="java"%>
<%@taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"%>
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="$(@FORM[]supporting-adapter[*])" delim="!" valueSeparator="!" default="<%=com.infoengine.au.NamingService.getVMName()%>"/>
<ie:param name="ATTRIBUTE" data="Customer1"/>
<ie:param name="ATTRIBUTE" data="Emmision"/>
<ie:param name="ATTRIBUTE" data="Engine"/>
<ie:param name="ATTRIBUTE" data="healthStatus"/>
<ie:param name="TYPE" data="wt.projmgmt.admin.Project2"/>
<ie:param name="WHERE" data="()"/>
</ie:webject>
we write jsp as
<html>
<body>
<ie:task uri="ext/NEWEXAMPLE.xml" processor="com.windchill.wcdev.Windchill"/>
<ie:webject name="Display-Table" type="DSP">
<ie:param name="ATTRIBUTE" data="S.No,Customer1,Emmision,Engine,healthStatus" delim=","/>
<ie:param name="HEADER" data="S.No,CUSTOMER,EMISION NORMS,ENGINE MODEL,STATUS" delim=","/>
<ie:param name="BORDER" data="1"/>
<ie:param name="GROUP_IN" data="project"/>
</ie:webject>
</html>
</body> We have a table, but we would like to fill a certain cell in the STATUS table with a specific color, such as RED, GREEN, or YELLOW.how to do this
Hi @AR_9920456
Usually you can set a CSS style to the text in the table, and based on the CSS style it can be shown as you need by your conditions.
I usually write DataUtility where I assign own CSS style based on my conditions.
PetrH
