I have a task to test use of DTI on our Windchill PDMLink instance/configuration. My first responsibility for that is to put together a user test plan. We are currently on version 11 of PDMLink but will be upgrading to 12.x, including the plugin, sometime in the next few months. Where can I find information on the changes/differences between DTI for version 11 and 12? Is there a "user guide" for DTI?
Barry Hastings
You can use the What's New section on of the online WCHC from PTC technical support to find any new updates. I looked through it quickly and did not see anything.
The best documentation is located in the WCHC: https://support.ptc.com/help/wnc/r12.0.2.0/en/index.html#page/Windchill_Help_Center/DTIAbout.html
