Hello @伟张_10329518
If you turn on the custom template tasks, then you need to define own custom template for each task node.
or you can use Task Form Template where you can define how the task should looks like.
After you create Template Form task, you define the Form on the task in the workflow .
Using Custom Task Form Templates in Windchill 11.0
PetrH
Hello @伟张_10329518
PetrH
