odata reporting domain
rleir
Hi Team
Does ODATA Reporting Domain work for you? I get 500 on all tests.
curl -X 'GET' \
'https://DOMAIN.com:443/Windchill/servlet/odata/v1/Reporting/OpenChangeNoticess?%24count=false' \
-H 'accept: application/json'
java.lang.NullPointerException
at com.ptc.odata.core.entity.processor.ProviderProcessor.readEntityCollection(ProviderProcessor.java:254)
at com.ptc.odata.core.entity.processor.EntityProviderProcessor.readEntityCollection(EntityProviderProcessor.java:114)
at com.ptc.odata.windchill.entity.service.WcEntityProviderProcessor.readEntityCollection(WcEntityProviderProcessor.java:290)
at org.apache.olingo.server.core.ODataDispatcher.handleEntityCollectionDispatching(ODataDispatcher.java:529)
at org.apache.olingo.server.core.ODataDispatcher.handleEntityDispatching(ODataDispatcher.java:511)
at org.apache.olingo.server.core.ODataDispatcher.handleResourceDispatching(ODataDispatcher.java:152)
at org.apache.olingo.server.core.ODataDispatcher.dispatch(ODataDispatcher.java:118)
at org.apache.olingo.server.core.ODataHandlerImpl.processInternal(ODataHandlerImpl.java:164)
at org.apache.olingo.server.core.ODataHandlerImpl.process(ODataHandlerImpl.java:85)
at org.apache.olingo.server.core.ODataHttpHandlerImpl.process(ODataHttpHandlerImpl.java:74)
at org.apache.olingo.server.core.LocalODataHttpHandlerImpl.process(LocalODataHttpHandlerImpl.java:31)
at org.apache.olingo.server.core.ODataHttpHandlerImpl.process(ODataHttpHandlerImpl.java:88)
at com.ptc.odata.windchill.entity.service.RetryableRequestMediator.process(RetryableRequestMediator.java:476)
at com.ptc.odata.windchill.servlet.WcRestServlet.service(WcRestServlet.java:200)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:764)
WC 12.0.2
Am I doing something wrong?
cheers -- Rick
HelesicPetr
(To:rleir)
Hi @rleir
It's a pity if you don't have time to contact PTC.
If you don't do that no one will do it for you and the issue will never be solved..
PetrH
10 REPLIES 10
rleir
(To:rleir)
Maybe this article is a clue to the answer?
WRS Reporting Domain does not apply Java Method on WRS 2.3
https://www.ptc.com/en/support/article/CS366253
HelesicPetr
(To:rleir)
Hi @rleir
What Windchill version do you use?
In Windchill 12.0.2.2 I can't find Reporting Domain.
PetrH
rleir
(To:HelesicPetr)
Hi Petr
Do you have CPS-7?  I think the Reporting Domain appeared then.
See it discussed in WRS 2.3 on page 188.
https://www.ptc.com/support/-/media/support/refdocs/Windchill_REST_Services/2,-d-,3/wrs.pdf?sc_lang=en
cheers -- Rick
HelesicPetr
(To:rleir)
Hi @rleir
In my case the API does not work.
Can not load the RestApi page for the PTCReportingDomain
Error in a browser
Errors in a MS Log
2022-10-04 09:08:58,451 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.queryBuilder.QueryBuilderUtil admin - cvc-complex-type.2.4.b: The content of element 'operand' is not complete. One of '{column, constant, keyword, function, reportAttributeReference, subQuery, reportViewAttribute}' is expected.
2022-10-04 09:08:58,451 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.queryBuilder.QueryBuilderUtil admin - FATAL ERROR at Line Number: 116 Column Number: 35
2022-10-04 09:08:58,452 ERROR [ajp-nio-127.0.0.1-8010-exec-5] com.ptc.windchill.enterprise.reportBuilder.ReportBuilderDataManager admin - An error was encountered upgrading report template org.xml.sax.SAXParseException; lineNumber: 116; columnNumber: 35; cvc-complex-type.2.4.b: The content of element 'operand' is not complete. One of '{column, constant, keyword, function, reportAttributeReference, subQuery, reportViewAttribute}' is expected.
	at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
2022-10-04 09:04:03,212 INFO  [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err  - java.lang.NullPointerException
2022-10-04 09:04:03,212 INFO  [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err  - 	at com.ptc.odata.docs.ODataSwaggerContext.cacheMetadata(ODataSwaggerContext.java:213)
2022-10-04 09:04:03,212 INFO  [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err  - 	at com.ptc.odata.docs.ODataSwaggerContext.getSchemas(ODataSwaggerContext.java:71)
2022-10-04 09:04:03,212 INFO  [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err  - 	at com.ptc.odata.docs.ODataSwaggerPathBuilder.<init>(ODataSwaggerPathBuilder.java:65)
2022-10-04 09:04:03,212 INFO  [ajp-nio-127.0.0.1-8010-exec-1] wt.system.err  - 	at com.ptc.odata.docs.WcODataSwaggerBuilder.<init>(WcODataSwaggerBuilder.java:53)
I guess that there is some error in parsing and it could be a bug.
PetrH
rleir
(To:HelesicPetr)
Petr:
Maybe that means you have bad QML in one of your reports? Unfortunately, that could be any one of your reports. Unless the log error names the report, you may need to open every report template in QueryBuilder or ReportBuilder?
cheers -- Rick
HelesicPetr
(To:rleir)
@rleir
Good point. I haven't thought about that so much.
I will check it but I guess that there are just OOTB reports. in the system.
PetrH.
rleir
(To:rleir)
Team
I have just been checking release notes for recent CPS versions, and found no mention of this problem or any fixes for it.
https://support.ptc.com/appserver/cs/update_advisor/update_advisor.jsp
https://www.ptc.com/en/support/article/CS273372
Is there another way to find which release fixes this issue?
Rick
HelesicPetr
(To:rleir)
Hi @rleir
Yes open a case to contact PTC support directly and ask them.
May be the issue has not been reported yet .
If Article does not exists it can not be in the CPS release notes.
PetrH
rleir
(To:HelesicPetr)
Agreed, Petr.  But I don't have time for PTC support cases, sorry! Maybe the moderators will take it upon themselves to pass a link to this thread over to whoever is responsible for QA.
cheers -- Rick
HelesicPetr
(To:rleir)
Hi @rleir
PetrH
