I'm no longer using cuted threads, I'm rolling my threads now.
The values, by default, for the hole feature is for cutted threads, for rolled ones the drill diameter must be bigger.
My question is, does any one knows if its possible to changethe drill diameter value? if the answer is YES, how can I do this?
Hello, there is a config.pro option "hole_diameter_override", set to "yes", allows you to change the hole diameter in the hole feature.
John
John
Regards
