11-Garnet
Nov 8, 2014 12:06 AM UTC
Absolute accuracy recommendation for consumer electronics
Everyone,
We could use some advice regarding what other companies, particularly those in consumer electronics, are using for accuracy values in Creo. We've been using relative accuracy as a default, and of course that comes with a lot of issues. We're exploring values for absolute accuracy, and we thought to reach out to the community to hear your experiences. We've heard that Motorola, for example, uses 0.003 mm. Can anyone share what you're using and successes and failures from your approach? Thanks in advance.
David R. Martin II
Senior CAD Application Specialist
Amazon
    Nov 8, 2014 12:08 AM UTC
    .001 mm absolute is what I have been using for tiny parts
    Nov 10, 2014 8:18 AM UTC
    We are using 0.005 mm.
    Best regards
    Bjarne Frandsen | Technology Specialist, MCAD
    Phone: +45 9684 4825 | Email: -
    [cid:image001.png@01CDCC9C.5B8352F0]
    Bang & Olufsen A/S | Peter Bangs Vej 15 | DK-7600 Struer | Denmark
    www.bang-olufsen.com
    Nov 10, 2014 2:43 PM UTC
    I've been using 0.0001" / 0.00254mm (the default when choosing absolute accuracy) for everything since I started on Proe back in 1996, rev. 16. It has generally served me well; I've had few occasions where I needed to tweak it. My biggest accuracy related problems have been with files created with relative accuracy.
    Nov 10, 2014 8:24 PM UTC
    Hi Dave - we make injection moulds and have been using 0.0002" (0.005mm) as
    our default accuracy for 15 years.
    Regards
    Gary Pitt
    Columbia Plastics Ltd
    19320-60th Ave
    Surrey, B.C.
    V3S 3M2
    604 530 9990 Ext 236
    Nov 10, 2014 9:47 PM UTC
    Discussion of absolute accuracy should include the typical part size, no?
    John
    Nov 10, 2014 10:18 PM UTC
    Same here, .0002” absolute accuracy for over 17 years now… with an occasional deviation by a .0001” to either side… we stay clear of relative accuracy.
    Paul
    Paul Mailloux Cad/Cam Applications Engineer
    NyproMold, Inc.
    144 Pleasant St, Clinton, MA 01510 ▪ www.nypromold.com
    Nov 11, 2014 2:06 PM UTC
    In Reply to John Moody:
    Yes and no, it has to do both with the size of the part, and the size of the smallest features you want to include with them. These features create small vertices and curves which affect part stability. We make sheet metal parts and use about 0.0025" (the smallest size typically available given our dimensions).
