Any way to convert backwards from Prime (mcdx) to MC15-era (xmcd) file format?
Is there a way? Possibly through an intermediate format via export-then-import process?
23-Emerald V
@VladimirN wrote:
No, there is no such reverse option.
P.S. Here's what you can do:
1. Save your worksheet in "PDF/XPS/RTF" format.
2. Manually type the contents of the file.
Rather than use pdf/etc output, I either:
  • Open Mathcad Prime and M15 in side-by-side windows.  This has the advantage of being able to check partial results (by adding new expressions) when bug hunting.
  • Paste images of the original worksheet directly into the new worksheet.  This makes it easier to check when looking for typos or dealing with wide expressions, and helps retain the provenance.
Stuart
Of course, if I weren't so lazy, I'd probably be tempted to write a tridirectional mcdx-LaTeχ-xmcd converter. The temptation has bubbled perilously close to the surface on a couple of occasions, but so far I've successfully managed to suppress it.
Cut and Paste from the Prime worksheet to the 15 spreadsheet. Only issue is if you have new functions that 15 does not support.
18-Opal
That does not work,
23-Emerald V
Stuart
Yes, you can do that too.
