Coupled differential equations issue
  • November 6, 2013
  • 2 replies
  • 5132 views
I Am having an issue with writing down coupled differential equations for radioactive decay! What is know is
dN/dt=-λN
so N=N0exp-λt
where λ=ln(2)/τ where τ is the half life of each element
I calculated all of the λ values and was then asked to write down the couples differential equations for the decay/creation of each element
dNn/dt=λn-1*Nn-1 -λnNn
NNot sure how to do this on MathCad!
They will be getting solved via rkfixed function but when I input the equations in the form above I get "a name is required here" error
There is an image below with my question sheet! Any help would be great
Maybe you would like to show what you have done so far by posting your Mahcad sheet.
amcmillan1-VisitorAuthor
HHow do I do that?
Alison McMillan wrote:
HHow do I do that?
The same way as you attached your pic.
But in a reply you have to switch to "advanced editor" first. You do so by clicking "Use advanced editor" at the upper right.
Now you have the option to attach files at the end.
There is no need to zip the files yourself as this will be done automatically.
Mathcad offers a more natural way to write and solve differential equations, namely via a solve block and the function odesolve(). You can select the numeric algorithm used by right clicking the word Odesolve. Normally there should be no reason to change the default "Adams/BDF"- Interestingly enough even chosing "Fixed" gives a satisfacory result this time.
Again also this function unfortunately does not support units in Mathcad 15 and below. One of the few advantages of Prime is that you are allowed to use units with odesolve, too.
EDIT: Again, see Alans post. It should NOT be surprising that "Fixed" works here. The reason is that I had set the number of points to 10^4 in this sheet (without being aware of 😉
Thanks so much guys, you have been great help:)
I think I understand where I was going wrong! MathCad is extremely tedious at time especially for a beginner like me!
Thanks again much appreciated
