Date Calendar and Time functions.mcd
Here is a selection of functions for dates, calendars, and times. Also included is a calendar component that allows a date to be selected by the user. The scripted components were all written by me, but the additional functions at the end of the worksheet were not. In fact, I don't know who did write some of them, but if the author of those functions, or someone who knows who the author is, reads this then please let me know who did write them so I can credit them correctly.
Jun 09 2015: Added a worksheet for Mathcad Prime. This includes only the limited set of functions not based on scripted components.
I'm not going mad.........Am I?????
Think Ziyad removed it
Mike
RichardJ19-TanzaniteAuthor
i think if just a time is given it should be assumed to be current date rather than dec 1899
I don't much care for that behavior either, but I'm just hijacking a VBscipt function, and that's the way it works. The only way I could fix it would be to do a fair amount of string handling or regular expression matching to trap the case when there is only a time. Too much work. Sorry.
thats fine Richard. I don't want to impose a hard solution for a small problem.
you have already helped me alot with date stuff.
Thank you
Did you get time to change SplitDate function to be able to use a vector of dates
Sorrry, not yet. It turned into a very busy weekend. I will try and get to it tomorrow.
OK, I have uploaded a new version of the document. SplitDate and AssembleDate now handle multiple dates at one time.
For completeness, I also added the functions form here:
http://communities.ptc.com/docs/DOC-1431
to the end of the document.
Very helpful.  Thanks
23-Emerald V
Neat.  Good work.
Neat.  Good work.
Thanks. I just felt my head swell slightly
Richard,
Your worksheet on dates does show where some of the functions came from.  One Terry Hendicott who does not claim creation but lists the book that they came from.  They are a translation from C++ functions in the reference.
Glad to see contributions are reused - refined and upgraded.
Cheers.
