Mathcad 15 help file not available; Mathcad Prime 1.0 won't convert files
I recently bought Mathcad Prime 1.0 which comes with a copy of Mathcad 15.
I installed both, but at first Mathcad 15 did not work. I believe this is a continuation of the problem I had with Mathcad 14 not working on Windows 7. (By the way, I got email from people who had the same problem.) Recently, however, M15 told me to reinstall, so I did, and it worked.
Two problems.
1. The help file does not work for M15, and M15 tells me "The path to the specified file, C:\Program Files (x86)\Mathcad\Mathcad 15\doc\help_en\help\mcad.htm, is incorrect. Run the installation of the corresponding components to correct this problem."
When I go to C:\Program Files (x86)\Mathcad\Mathcad 15\doc\help_en\help, there is no mcad.htm.
2. Mathcad Prime does not convert files. It simply says failed, could not start Mathcad conversion process.
I believe I am entitled to tech support for 1 yr after purchase. Can anyone tell me how to do that? Is it possible to talk to someone about problems, or even do an online chat?
Help!
Bill Edelstein
Johns Hopkins University
Baltimore
