Mathcad and Windows 7
After a several years of inactivity I have started using Matchcad 14 again. Previously I was running under Windows XP and Windows Vista and the program worked fine. Now I am using Windows 7 and a number of features are no longer working.
Array table formatting doesn't work. I can format a result as a matrix but not a table.
2D plots work but not 3D plots.
None of the Control buttons (Radio, Push Button, Slider, etc.) work.
These are all the problems I have found so far. The program seems to be working fine in other respects.
Has anyone out there encountered a compatibility problem with Mathcad 14.0 and Windows 7?
I would appreciate any help I can get.
