Can anyone tell me if it's possible to show "limit dimensions" in a repeat region driven table?
I have several parts controlled by a family table. There is a hole that most of the parts are .454/.452 but there are a couple that this hole is .563/.562. When I add the dimension to the table it adds the mean value. Since the tolerance is not the same I can not just add a tolerance to the end the the value (ie... .453+.001/-.001).
Any help would be appricated.
Kevin Brandt
Contract Project Engineer
