Wally, Unfortunately, I am not sure if there are any comprehensive documentation on how to configure the "config.pro" file. Before Wildfire, you had to have magical powers to understand the syntax of the file. Now, it is a bit easier because if you access this file inside PROE, it will guide you on what you need to set, although you still need to have an idea of what variable you are looking for. The users and on-line help may prove useful. Otherwise, keep playing with it until you get what you want.
