BILL OF MATTERIAL (BOM)
ptc-2127864
I have a parametric BOM in the drawing file where in a single row i need to form 2 row of a single sentence. i tried a lot to wrap the sentence in a single row but it didnot work can anyone tell me is there any procedure to wrap it whithin a single row. Regards Abhaya
7 REPLIES 7
abhaya, What do you mean exactly? If it's some long sentence parameter for each BOM item, I don't think there's any way to easily deal with this, but if you mean some kind of one-time header information, you can easily divide your sentence into two pieces, make a "tall" cell with two lines of entered text, and/or merge cells. Depends on what you are trying to do. You could use string parameter logic to divide a sentence, but that could get pretty cumbersome. David
David, Thanks again for giving answer what i actually wanted is that i want to make 2 sentence in single block of the BOM without merging any other row. (I have a big description of a part )so can i do that. Regards Abhaya
abhaya, I don't see how this can be done automatically for each part in the BOM. Of course, such two-line text can be entered manually into a cell, but I don't think that's what you are looking for. David
Abayha, This seems like a feature that should be available, I am having the same problem I have to shrink the text so small for the description that it can't be read! Regards, Scott
Try something like the following (add as relations to repeat region) :
NUM = rpt_qty
IF EXISTS ("ASM_MBR_BULK_ITEM")
IF EXISTS ("ASM_MBR_DASH")
IF ASM_MBR_DASH == YES
NUM = "-"
ELSE
IF ASM_MBR_BULK_ITEM == YES
NUM = "AR"
else
NUM = rpt_qty
ENDIF
ENDIF
ELSE
NUM = "AR"
else
NUM = rpt_qty
ENDIF
ENDIF
ELSE
NUM = "-"
else
NUM = rpt_qty
ENDIF
ENDIF
ENDIF
partnox = string_length(asm_mbr_part_no)
partno1= asm_mbr_part_no
partno2= ""
if partnox > 18
endlen1 = ceil(partnox/2)
endlen2 = endlen1 + 1
endlen3 = floor(partnox/2)
partno1 = extract(asm_mbr_part_no,1,endlen1)
partno2 = extract(asm_mbr_part_no,endlen2,endlen3)
endif
spec = string_length(asm_mbr_specification)
spec1= asm_mbr_specification
spec2= ""
if spec > 18
spec_18 = extract(asm_mbr_specification,18,1)
if spec_18 == " "
endlen = spec-18
spec1=extract(asm_mbr_specification,1,17)
spec2=extract(asm_mbr_specification,19,endlen)
else
spec_17 = extract(asm_mbr_specification,17,1)
if spec_17 == " "
endlen = spec-17
spec1=extract(asm_mbr_specification,1,16)
spec2=extract(asm_mbr_specification,18,endlen)
else
spec_16 = extract(asm_mbr_specification,16,1)
if spec_16 == " "
endlen = spec-16
spec1=extract(asm_mbr_specification,1,15)
spec2=extract(asm_mbr_specification,17,endlen)
else
spec_15 = extract(asm_mbr_specification,15,1)
if spec_15 == " "
endlen = spec-15
spec1=extract(asm_mbr_specification,1,14)
spec2=extract(asm_mbr_specification,16,endlen)
else
spec_14 = extract(asm_mbr_specification,14,1)
if spec_14 == " "
endlen = spec-14
spec1=extract(asm_mbr_specification,1,13)
spec2=extract(asm_mbr_specification,15,endlen)
else
spec_13 = extract(asm_mbr_specification,13,1)
if spec_13 == " "
endlen = spec-13
spec1=extract(asm_mbr_specification,1,12)
spec2=extract(asm_mbr_specification,14,endlen)
else
spec_12 = extract(asm_mbr_specification,12,1)
if spec_12 == " "
endlen = spec-12
spec1=extract(asm_mbr_specification,1,11)
spec2=extract(asm_mbr_specification,13,endlen)
else
spec_11 = extract(asm_mbr_specification,11,1)
if spec_11 == " "
endlen = spec-11
spec1=extract(asm_mbr_specification,1,10)
spec2=extract(asm_mbr_specification,12,endlen)
else
spec_10 = extract(asm_mbr_specification,10,1)
if spec_10 == " "
endlen = spec-10
spec1=extract(asm_mbr_specification,1,9)
spec2=extract(asm_mbr_specification,11,endlen)
else
spec_9 = extract(asm_mbr_specification,9,1)
if spec_9 == " "
endlen = spec-9
spec1=extract(asm_mbr_specification,1,8)
spec2=extract(asm_mbr_specification,10,endlen)
else
spec_8 = extract(asm_mbr_specification,8,1)
if spec_8 == " "
endlen = spec-8
spec1=extract(asm_mbr_specification,1,7)
spec2=extract(asm_mbr_specification,9,endlen)
else
spec_7 = extract(asm_mbr_specification,7,1)
if spec_7 == " "
endlen = spec-7
spec1=extract(asm_mbr_specification,1,6)
spec2=extract(asm_mbr_specification,8,endlen)
else
spec_6 = extract(asm_mbr_specification,6,1)
if spec_6 == " "
endlen = spec-6
spec1=extract(asm_mbr_specification,1,5)
spec2=extract(asm_mbr_specification,7,endlen)
else
spec_5 = extract(asm_mbr_specification,5,1)
if spec_5 == " "
endlen = spec-5
spec1=extract(asm_mbr_specification,1,4)
spec2=extract(asm_mbr_specification,6,endlen)
else
spec_4 = extract(asm_mbr_specification,4,1)
if spec_4 == " "
endlen = spec-4
spec1=extract(asm_mbr_specification,1,3)
spec2=extract(asm_mbr_specification,5,endlen)
else
spec_3 = extract(asm_mbr_specification,3,1)
if spec_3 == " "
endlen = spec-3
spec1=extract(asm_mbr_specification,1,2)
spec2=extract(asm_mbr_specification,4,endlen)
else
spec_2 = extract(asm_mbr_specification,2,1)
if spec_2 == " "
endlen = spec-2
spec1=extract(asm_mbr_specification,1,1)
spec2=extract(asm_mbr_specification,3,endlen)
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
desc = string_length(asm_mbr_description)
desc1 = asm_mbr_description
desc2 = ""
if desc > 20
desc_20 = extract(asm_mbr_description,20,1)
if desc_20 == " "
endleng =desc-20
desc1=extract(asm_mbr_description,1,19)
desc2=extract(asm_mbr_description,21,endleng)
else
desc_19 = extract(asm_mbr_description,19,1)
if desc_19 == " "
endleng =desc-19
desc1=extract(asm_mbr_description,1,18)
desc2=extract(asm_mbr_description,20,endleng)
else
desc_18 = extract(asm_mbr_description,18,1)
if desc_18 == " "
endleng =desc-18
desc1=extract(asm_mbr_description,1,17)
desc2=extract(asm_mbr_description,19,endleng)
else
desc_17 = extract(asm_mbr_description,17,1)
if desc_17 == " "
endleng =desc-17
desc1=extract(asm_mbr_description,1,16)
desc2=extract(asm_mbr_description,18,endleng)
else
desc_16 = extract(asm_mbr_description,16,1)
if desc_16 == " "
endleng =desc-16
desc1=extract(asm_mbr_description,1,15)
desc2=extract(asm_mbr_description,17,endleng)
else
desc_15 = extract(asm_mbr_description,15,1)
if desc_15 == " "
endleng =desc-15
desc1=extract(asm_mbr_description,1,14)
desc2=extract(asm_mbr_description,16,endleng)
else
desc_14 = extract(asm_mbr_description,14,1)
if desc_14 == " "
endleng =desc-14
desc1=extract(asm_mbr_description,1,13)
desc2=extract(asm_mbr_description,15,endleng)
else
desc_13 = extract(asm_mbr_description,13,1)
if desc_13 == " "
endleng =desc-13
desc1=extract(asm_mbr_description,1,12)
desc2=extract(asm_mbr_description,14,endleng)
else
desc_12 = extract(asm_mbr_description,12,1)
if desc_12 == " "
endleng =desc-12
desc1=extract(asm_mbr_description,1,11)
desc2=extract(asm_mbr_description,13,endleng)
else
desc_11 = extract(asm_mbr_description,11,1)
if desc_11 == " "
endleng =desc-11
desc1=extract(asm_mbr_description,1,10)
desc2=extract(asm_mbr_description,12,endleng)
else
desc_10 = extract(asm_mbr_description,10,1)
if desc_10 == " "
endleng =desc-10
desc1=extract(asm_mbr_description,1,9)
desc2=extract(asm_mbr_description,11,endleng)
else
desc_9 = extract(asm_mbr_description,9,1)
if desc_9 == " "
endleng =desc-9
desc1=extract(asm_mbr_description,1,8)
desc2=extract(asm_mbr_description,10,endleng)
else
desc_8 = extract(asm_mbr_description,8,1)
if desc_8 == " "
endleng =desc-8
desc1=extract(asm_mbr_description,1,7)
desc2=extract(asm_mbr_description,9,endleng)
else
desc_7 = extract(asm_mbr_description,7,1)
if desc_7 == " "
endleng =desc-7
desc1=extract(asm_mbr_description,1,6)
desc2=extract(asm_mbr_description,8,endleng)
else
desc_6 = extract(asm_mbr_description,6,1)
if desc_6 == " "
endleng =desc-6
desc1=extract(asm_mbr_description,1,5)
desc2=extract(asm_mbr_description,7,endleng)
else
desc_5 = extract(asm_mbr_description,5,1)
if desc_5 == " "
endleng =desc-5
desc1=extract(asm_mbr_description,1,4)
desc2=extract(asm_mbr_description,6,endleng)
else
desc_4 = extract(asm_mbr_description,4,1)
if desc_4 == " "
endleng =desc-4
desc1=extract(asm_mbr_description,1,3)
desc2=extract(asm_mbr_description,5,endleng)
else
desc_3 = extract(asm_mbr_description,3,1)
if desc_3 == " "
endleng =desc-3
desc1=extract(asm_mbr_description,1,2)
desc2=extract(asm_mbr_description,4,endleng)
else
desc_2 = extract(asm_mbr_description,2,1)
if desc_2 == " "
endleng =desc-2
desc1=extract(asm_mbr_description,1,1)
desc2=extract(asm_mbr_description,3,endleng)
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
matl = string_length(asm_mbr_material)
matl1 = asm_mbr_material
matl2 = ""
if matl > 16
matl_16 = extract(asm_mbr_material,16,1)
if matl_16 == " "
endleng =matl-16
matl1=extract(asm_mbr_material,1,15)
matl2=extract(asm_mbr_material,17,endleng)
else
matl_15 = extract(asm_mbr_material,15,1)
if matl_15 == " "
endleng =matl-15
matl1=extract(asm_mbr_material,1,14)
matl2=extract(asm_mbr_material,16,endleng)
else
matl_14 = extract(asm_mbr_material,14,1)
if matl_14 == " "
endleng =matl-14
matl1=extract(asm_mbr_material,1,13)
matl2=extract(asm_mbr_material,15,endleng)
else
matl_13 = extract(asm_mbr_material,13,1)
if matl_13 == " "
endleng =matl-13
matl1=extract(asm_mbr_material,1,12)
matl2=extract(asm_mbr_material,14,endleng)
else
matl_12 = extract(asm_mbr_material,12,1)
if matl_12 == " "
endleng =matl-12
matl1=extract(asm_mbr_material,1,11)
matl2=extract(asm_mbr_material,13,endleng)
else
matl_11 = extract(asm_mbr_material,11,1)
if matl_11 == " "
endleng =matl-11
matl1=extract(asm_mbr_material,1,10)
matl2=extract(asm_mbr_material,12,endleng)
else
matl_10 = extract(asm_mbr_material,10,1)
if matl_10 == " "
endleng =matl-10
matl1=extract(asm_mbr_material,1,9)
matl2=extract(asm_mbr_material,11,endleng)
else
matl_9 = extract(asm_mbr_material,9,1)
if matl_9 == " "
endleng =matl-9
matl1=extract(asm_mbr_material,1,8)
matl2=extract(asm_mbr_material,10,endleng)
else
matl_8 = extract(asm_mbr_material,8,1)
if matl_8 == " "
endleng =matl-8
matl1=extract(asm_mbr_material,1,7)
matl2=extract(asm_mbr_material,9,endleng)
else
matl_7 = extract(asm_mbr_material,7,1)
if matl_7 == " "
endleng =matl-7
matl1=extract(asm_mbr_material,1,6)
matl2=extract(asm_mbr_material,8,endleng)
else
matl_6 = extract(asm_mbr_description,6,1)
if matl_6 == " "
endleng =matl-6
matl1=extract(asm_mbr_material,1,5)
matl2=extract(asm_mbr_material,7,endleng)
else
matl_5 = extract(asm_mbr_material,5,1)
if matl_5 == " "
endleng =matl-5
matl1=extract(asm_mbr_material,1,4)
matl2=extract(asm_mbr_material,6,endleng)
else
matl_4 = extract(asm_mbr_material,4,1)
if desc_4 == " "
endleng =matl-4
matl1=extract(asm_mbr_material,1,3)
desc2=extract(asm_mbr_material,5,endleng)
else
matl_3 = extract(asm_mbr_material,3,1)
if matl_3 == " "
endleng =matl-3
matl1=extract(asm_mbr_material,1,2)
matl2=extract(asm_mbr_material,4,endleng)
else
matl_2 = extract(asm_mbr_material,2,1)
if matl_2 == " "
endleng =matl-2
matl1=extract(asm_mbr_material,1,1)
matl2=extract(asm_mbr_material,3,endleng)
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
endif
One can only wrap the Title. The repeat region parameters cannot be wrapped. I have not tried with relations. I normally export as csv file and then paste it as an Excel file. This is a long standing request, I believe is available in Creo 2.0.
It is available in Creo 2.0 !
