Check the config option ida_prefix_in_basic_dim_box. I think that is it but considering I can't even figure out how to make a dimension "basic" I can't test it. Any help on that would be appreciated. thanks
Hello ,
As per the article - CS11097:
As of Wildfire 4.0, the text appearing outside of the basic dimension box is current fuctionality.
Some customers want some text inside or outside, therefore it will be necessary to use the following syntax:
For outside the box - @Dtext or text@D
For inside the box - @[@Dtext@] or @[text@D@]
This syntax interacts correctly with the basic dimension box.
Which release of Pro/ENGINEER or Creo Parametric are you using?
Amit
