I made this back in WF2 for dxf but should be the same now except select STEP:
Make a directory and back up all your files out of intra-link into it.
Copy all of your config files from your workspace into that folder also.
Open a DOS window in that directory and type:
C:\ptc\proeWildfire2\bin\pro_batch (or whatever your installation and level is).
Select File, Browse and pick all the drawings.
Select Preference, Set Preference. Plot as a PostScript.
Enter Batch001 into the Batch File: box. Enter \ptc\proeWildfire2\bin\proe1 into the Pro/Engineer Command Box.
This next step is extra but I like to do it.
Add these options to your config.pro that you put in the folder (if you are outputting dxfs instead of pdf).
DXF_EXPORT_FORMAT 2000
DXF_OUT_DRAWING_SCALE NO
DXF_OUT_SCALE_VIEWS NO
DXF_OUT_SEP_DIM_W_BREAKS NO
DXF_OUT_STROKE_TEXT YES
INTF2D_OUT_ENHANCED_ENTS SPLINE_AND_HATCH
INTF_OUT_LAYER NONE
INTF2D_OUT_ACAD_MTEXT NO
INTF2D_OUT_ACAD_TEXT_ALIGN
INTF2D_OUT_PNT_ENT
INTF2D_OUT_OPEN_LOG_WINDOW NO
The final step is to hit Schedule, Start the Task (after you hit File, Save).
This should bring up the Schedule box and click OK after 0 hours.
Set Adobe Distiller to run in the folder that the PostScript files come out in or collect the dxf files out of that folder. It should output multiple sheets as one multiple sheet pdf and dxfs as the name of the file with and underscore then the sheet number.
Hi Folks,
I am completely unfamiliar with batch files for getting ProE to do stuff. I have a comment from our ECAD brethren that their latest release supports viewing of STEP files of parts so I am wondering if it is possible to run some sort of batch process that takes existing electro-mechanical part files and saves them as same name STEP files?
Many thanks in advance.
P.S. very little feedback so far on the internal PDF creation from WF4. I got one saying don't use it due to this sort of problem. Seems very strange that PTC does not have this PDF creation process nailed.
Regards, Brent Drysdale
Mechanical Designer
Tait Electronics Ltd (www.taitworld.com)
New Zealand
Ph. +64 3 358 1093
This email, including any attachments, is only for the intended addressee. It is subject to copyright, confidential and may be the subject of legal or other privilege, none of which is waived or lost by reason of this transmission. If the receiver is not the intended addressee, please accept our apologies, notify us by return, delete all copies and perform no other act on the email. Unfortunately, we cannot warrant that the email has not been altered or corrupted during transmission.
