Bradford Sanitary Ferrules
nsfreund
Pro-Gurus,
I apologize if this is the wrong forum, but I am trying to see if anyone
has any models of Bradford Sanitary Ferrules they could share. I have
scoured the internet to try and find out the "flange" end-dimensions,
but so far I have only been able to find the tube ID and OD along with
the length of the ferrule. I am trying to determine what the "flange"
end of the ferrule is (flange OD, flange OD flat dimension, etc.) If
anyone has any models or a detail of the flange end dimensions it would
be much appreciated. There is a controversy with some subassemblies here
where I work that involve designers specifying sanitary tube ferrules in
piping subassemblies. Not a good idea, so I am trying to correct the
problem since the flow analysis was done with 2" SCH10 pipe.
Of course as most of you know, 2" tube is actually 2.00" OD, while 2"
pipe is actually 2.375" ID.
Nick
0 REPLIES 0
