"Eric Mills" wrote:
To make an axis with two planes you need to select one plane and then another that is normal to the first plane. Pro-E doesn't need any more references to create an axis. Look at it this way there is a theoretical line between two planes normal to each other, so you can create an axis using the same logic. Eric
"" wrote:
..... Now my problem is when I come to redefine the placement of a component in the assembly, the datum plane I have just create is nowhere to be seen.....
