Hi Craig. Which release of Wildfire are you using? Ron's suggestion is very good and particularly the part of putting the feature in the footer so it always regens last.
In WF4 you can create the feature through the Analysis menu. Analysis--->Model--->Mass Properties will yield the Mass Prop dialog box.
At the bottom, change Quick to Feature--->Click Eyeglass icon for Preview--->Click Feature tab--->Select desired Params & Dtms--->Green check icon to complete.
In the Model Tree--->RightMouse to Rename the feature and Move to Footer. This method doesn't require any relations.
Jim
