"Phill Davis" wrote:
I am reverse engineering an aluminum motorcycle frame. It is constructed of 14 major parts, 6 extrusions and 8 castings. When doing the drawings, the extrusions are fairly straightforward and easy. But where I am having problems is when I draw the castings. They have different wall thicknesses, ribs, chamfers, rounds, etc. The problem is not with drawing the first piece of the frame, it is when I draw all of the succeeding parts. When I go to shell, chamfer, or round, I get into a lot of problems because the action I am trying to perform doesn't stop on just the piece I am currently constructing. For instance, a shell operation tries to shell the entire model up to that point, even though the previously constructed parts don't need it. Now I know that someone really proficient with such tasks could probably do it within a single part file. But for me, it just seemed easier to construct the model exactly as the original was constructed; one piece at a time. By starting as an assembly, then constructing each individual part within the assembly, it allowed me to more easily control the process and final shape of the individual parts. But now I am looking to bring the drawing back into a bigger assembly. Now I can bring the entire assembly into another drawing, but I am having problems with that as well. Whenever I insert an external assembly into another assembly, it works just as is should, until the next time I open the file. If I restart Pro E and try to reopen the parent assembly file, Pro E can't find any of the inserted assemblies, I have to go manually locate them one at a time. I don't understand why this is happening, because I can insert an individual part from an assembly, and it works every time the file is opened. But if I insert the entire assembly, contained in exactly the same folder, it can't find that.
"José Martinho Pelacani Junior" wrote:
In my opinion, you could use inheritance. You can create one part with only planes and coordinate system. Then, you use a inheritance to 'merge' each part into one. The negative point is to create the assembly again. The positive is having all dimensions in one model only.
Many thanks...it perfectly works for me.
I've actually posted an "Idea" about this for PTC to evaluate. Please vote on it if you are in favor of it. Should be close to the top of the list on this page"
http://communities.ptc.com/community/creo?view=idea#/?tagSet=undefined
