Curve by equation in a datum graph
ptc-1817592
I'm trying to create a datum graph that uses a continuous curve that is driven by a relation / equation without using a 'sketched' spline. Is there a way to do this, or do you need to create a datum curve and then import the curve into the graph? I'm not sure how I would create the datum curve with the relation that I currently have since the curve by equation needs to be in terms of x and y.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
