Datum attachment
Amcare
Datum attachment
I'm having trouble trying to attach a datum tag to a dim. Keeps telling me the part is not active. I'm using it to reference a Gtol callout.
Aaron I assuming that you are trying to create a GTOL in the assembly, in the GTOL box "Select Model", choose the part that the dimension is referencing. Otherwise you will get the error. Eric
Amcare
(To:eric.mills)
I need to attach the datums to dimensions in the dwg file, but won't let me.
