Security Alert Log4j Security Vulnerability. Click here to know more.
Dimensioning large radii on a drawing
BarryMason
When a drawing has a very large radius, I need to be able to show the centre point along with the curved radius. When the view appears on the drawing there is a large space between the centre and the radiused curve, which I would like to minimize. Ive seen it done on manual drawings where the radius leader is jogged (zig-zag) to depict the dimension. Can this be done on ProE?
You're not going to want to hear this, before Wildfire, it was possible to move "clip" radius center points as I recall. Here's a work-around I located: https://www.ptc.com/appserver/cs/view/solution.jsp?n=/35675.htm A day without sunshine is like night.
