I have a complete drawing all dims are in place. Now I need to add a couple tol callout. Where do I find the tool to turn "on" the tolerance in a dimension? Thanks! This thread is inactive and closed by the PTC Community Management Team. If you would like to provide a reply and re-open this thread, please notify the moderator and reference the thread. You may also use "Start a topic" button to ask a new question. Please be sure to include what version of the PTC product you are using so another community member knowledgeable about your version may be able to assist.
You need to add the config.pro option 'tol_display'. Set this to 'Yes'. When you go to properties for you dimension, the 'Tolerance Mode' drop down box should be availiable (which I assume must be greyed out for you).
The thing I don't like about this is that it turns on tolerances for ALL dimensions in the drawing. You also need to set tol_mode to "nominal". Then you can modify indiviual dimensions as needed. The default I believe is "limits".
Oh yeah, I remember that one. When I first added tol_display, all my dimensions had tolerances on. It was a case of 'yeah thats what I want, but not realy'. Need to set tol_mode also to nominal as above.
