I am using wildfire 2 and I bring a drawing in that was in 2001. I
select dimension to go from hole to hole and it will not select the
part. I drag the mouse all over the drawing and notice that only part of
the drawing objects highlights. I use unhide and some will work then I
go into my family parts and verification status and it seams to fix it
somewhat. Then I close the drawing and reopen and it starts all over
again. Is the a fix or is there a config file I need. Thanks
Dave Dills
Mechanical Designer
WEDECO
14125 South Bridge Circle
Charlotte, NC 28273
(704) 409-9731 work
(704) 839-9431 cell
