Drawing notes with dim refs
ptc-2079015
In WF 2 I remember making notes for counterbored holes that referenced the counterbore's dim value and after the note was complete the dimension would automatically erase itself so that there was no double dimensioning. In WF 4 it isn't doing that by default and leaves the dimension on the drawing. Any idea on the config.pro option that controlls that? C.Moyer
What are you talking about? This is not possible.
Hi Moyer, I don't have WF4 right now but i'm sure that if it can be done using WF2, surely WF4 also. Are you sure you input the correct dimension id in your notes? are you using the model's dimension id or draft dimension id in your notes?
