Hi all, I am trying to get a drawing into a word document. I have an exploded view which I need to show in an assembly instruction but am finding it hard to get just the lines into the doc.
Any help or advise would be helpful
Try exporting the Pro/E drawing as CGM (you may have to change the color scheme to black on white). MSOffice doesn't include the CGM import filter by default, but it can easily be added. The CGM format is a vector format, so it is resolution-independent. Not only are you able to zoom / scale the drawing without a loss of quality, but the file size should be a lot smaller, too. It should also look more professional than any raster format.
We added a config.pro option "dxf_out_stroke_text yes" that I think is related to the way text is created in CGM files (yes, I know the option says "dxf", but it's PTC, after all).
Other users have suggested printing to PDF, then copy-paste between Adobe Reader and MS Word. I don't like this because Adobe puts a raster image on the clipboard. You can change the resolution of the raster image in Adobe's preferences, but it is still a raster image. That means you have to use high resolution to get decent quality, and your file sizes will be quite large.
One user suggested embedding the Pro/E drawing into Word using OLE. Iusually say away from these types of solutions because they tend to carry a lot of extra baggage and may have unpredictable results.
One usersuggested taking a screen grab then pasting the screen grab into Word. Thatresults in the lowest resolution of any of the other suggestions, and probably should be avoided.
I have to agree with Andrew Kelly on this one. I have had the best results with CGM files for import into word. We don't use any special background color or other settings. Create the file using the print dialog & pick the CGM printer. You can control line weight & everything else just like you do for any printer.
We used to use HPGL but MS dropped support for that format many releases ago. Must have worked too well. The only downside with using any intermediate file format is you loose associativity. Using the OLE imbedding solves that but then only someone with Pro/E access is going to be able to open the Word doc.
