"Kevin Demarco" wrote:
On the page where you get the GCRI download look under the Additional Resources link on the right side of the page. There is a pdf document that explains how to set it up.
Julien,
Not sure if you found your answer, but if not, you can always save out as a .neu file, it is supposed to work up and down to any version level, althought just like all imports, three is no feature history
Brian
