"Chris Benner" wrote:
On your editing toolbar (wherever it may be on the screen) look for the tool I have marked #1 in my picture, and select it. you will get the toolbox you see on the right. Select the tool marked #2 to constrain the end of the line you want to extend, to the line you want to extend it to. Pick the end point of the first line, and the line you want it collinear to. There is also a button on the trim tool that will allow you to create a corner from tow perpendicular lines (a zero radius fillet).
Creo is so suck. This is not an extending a line. When I did as you show me, it changes that line to other position.
Creo software is so stupid.
Did you know that you can extend line in sketch by using Shift or CTRL key and dragging the line end point?
I can't get the line I am dragging to automatically grab the end point of the other line and close my sketch?
