Extremely slow response when adding parts into a large assembly
TrainStopper
8-Gravel
Hi Folks,
I'm experiencing long delays when adding a component to one of my larger
assemblies where I set up some simplified reps (first time I have used
them).
In this assembly, I have tried working in the Master Rep and simplified
reps and the delay is the same.
It takes 50 seconds to regenerate every time I add another part, in this
case a basic flat washer.
When I try the same thing on a similar assembly, nearly the same
assembly but it never had any simplified reps set up, there is no delay.
Is this problem possibly related to SPR # 1829619?
The problem is repeatable on 2 workstations in WF4 M080 & M090.
This problem only started after I set up simplified reps in an attempt
to improve responsiveness, but now it is worse than before.
I also experienced problems with attempting to retrieve any assembly
with a graphics rep, but I deleted all the graphics reps - at least all
the ones I could find - is there a way to search for different rep
states in an assembly?
I'm hoping to be able to find the problem and fix this assembly, its big
and I'd rather not start over but it is all but unusable now.
Thanks for any advice/troubleshooting tips you might have!
Walt Weiss
1 REPLY 1
Ok, I can eliminate the long delay by suppressing my mass property
calculation in the footer.
I don't know why it gets stuck there but at least I can work around it
for now.
Build M110 did not help that problem, but it did fix the measure delay
with large assemblies that appeared in build M100 - yay!
Walt Weiss
