Family Tables & Repeat Regions
meline
2-Explorer
Hi all,
I've set my model dimension to a limits tolerance mode. I then set up a family table for various instances based on this dimension being different values.Next Icreate a table on my drawing and set up repeat regions to pull the data from the family table.
I would like to have my drawing table display the dimension in a limits tolerance mode, but am unsure how to do it, or if it is even possible since the family table in the model only accepts nominal values. Any thoughts?
Thanks in advance.
mjenkins
(To:meline)
See TPI: 123115
Description
