Hi, this is possibly a really dumb question, but I can't seem to find the answer anywhere. I have a bunch of parts that I imported as dxf's from a 2D CAD program - all is fine, converted to 3D etc., and have assembled them into their sub-assemblies - however, there were inaccuracies in the source files obviously, and the alignment hole in the center of each part doesn't quite line up now that the outers of the parts themselves are aligned correctly. I thought that I could either move, delete or fill the existing alignment hole and if required recreate it - but how? I hoped that I might be simply able to hi-light the hole on the 3D part and delete it, but no way does that seem possible. I've attached one of the parts for reference. Secondly, if I have a stack of these as an assembly, can I punch a hole through them all while still assembled? Many thanks, Mike
