Gear Connection with a Bearing Joing
athomas1
I am having trouble defining a gearset (Using mechanism in Wildfire 2). According to the help files, I should be able to define a gearset by selecting pin joint axis, cylinder joint axis, bearing joint axis, or planar joint axis. However, Mechanism will not let me select a bearing joint axis for the gearset. I can't use a pin joint or a cylinder joint to get the desired reaction force measurements.
Has anyone run into this before? Is there a way to use the bearing joint axis to define a gearset?
0 REPLIES 0
