Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Ghost Object
mwimberly
6-Contributor
Ghost Object
I have a drawing that has some invisible link to a part that does not
exist anymore. I do a "where used" on the ghost and it doesn't list
anything but it still shows up when I save the drawing. I have checked
all the obvious areas and there is nothing. The only link that I find
is when I open the part as a document and search for the part number and
I find it in the code of the drawing. Is there a way to break this link
inside or outside or ProE
I did send this to both the ProE list and the Intralink list, sorry for
the redundancy.
Michael Wimberly
Engineering Applications Support Specialist II
Security & Survivability Systems
BAE Systems Land & Armaments
9113 Le Saint Drive
Fairfield, Ohio 45014 U.S.A.
(513) 881-4843 Direct
(513) 881-5087 Fax
(513) 881-9800 Main
These config options should clear that up for you. But apparently you
don't want to have them turned on for normal use, just when you want to
clean up those ghost objects that are stuck in a drawing (or layout I
suppose).
cleanup_drawing_dependencies yes
cleanup_layout_dependencies yes
Cheers
Doug Barton
Senior Mechanical Designer
Parker Hannifin Electronic Controls
Electronic Controls Division
1305 Clarence Avenue
Winnipeg, MB R3T 1T4 Canada
direct 204 453 3339 x309
fax 204 452 7156
www.vansco.ca
www.parker.com
2009-02-05 12:11 PM
Please respond to
"Wimberly, Michael (US SSA)" <->
To
cc
Subject
[proecad] - Ghost Object
anything but it still shows up when I save the drawing....
Mike,
Have you tried selecting File à Properties à Del Model from the Pro-E
drawing file? The drawing property options are shown in the attached JPEG.
Trying deleting the part model to see if it will break the link.
As for Pro/Intralink, it has been a few years since I have used it, so I
cannot answer that question. I use DesignDataManager (DDM) as an
alternative.
Chris Thompson
Pro-E Wildfire 2.0 & 3.0
SolidWorks Office Premium 2007 & 2009
mwimberly
6-Contributor
(To:mwimberly)
This worked. I had already made sure there were no extra models in the
drawing. There was a linked dependency that needed broken. This
procedure worked perfectly.
Thanks to all who replied.
Michael Wimberly
9113 Le Saint Drive
(513) 881-5087 Fax
(513) 881-9800 Main
