Good Day,
Thanks to Jeff Richardson who had the answer I was looking for.
My problem was in how I was constraining the model.
To hold the model in place I used 3 displacement constraint attached at pointson the bottom of the cylinder model.
1st one has all freedoms fix
2nd one has all freedoms fix except x translation is free to move
3rd one has all freedoms fix except x and z translation are free to move (depending on the orientation of the model freedoms may need to change. Make sure the constraints allow the model to expand and contract as it needs to "hint")
Apply apressure load to the inside surfaces of the cylinder
Model the thread surface at the pitch dia and apply a total load that repersents the force the endcap istransferring to the end of the cylinderon the thread surface.
run the analysis and it should get you close.
Happy Holidays,
Don A
