Best you can do is save the temp XLS as a separate worksheet. Then copy the contents into your clipboard. Hit the "Edit with Excel" on your family table, then paste the contents. I use this all the time for very similar parts. As I said in the other post, this will only work if the column structure is exactly the same. Good luck. Chris
Chris Benner
Autodesk ® Expert Elite
