Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
Thanks all, here is a couple answers. It is created automatically and you can not delete it. Anytime an item is hidden using the right mouse button it is added to that layer. Or if you use a sketch for a feature when it is turned off it is added to that layer. It is basically a collection of manually (RMB) or automatically hidden items. Michael Wimberly When you hide items in the model tree (right click a feature and select 'hide') or when they are automatically hidden like when you use a sketch to create a feature, they get placed on this hidden items 'layer'. There is no way to remove it that I know. I wish it acted just like regular layers, items in this 'layer' cannot be made visible by isolating another layer. The ability to hide features directly was added in WF1, but teh hidden items layer wasn't exposed to the user until WF2 I believe. Doug Schaefer
