Layers (drawings)
bmozley
Layers (drawings)
ProE users,
How do you create a layer to hide a curve in one view but not the other?
Brad
WF 3
You don't need a special layer (per se), but you have to set the layer
visibility for the view you want to be different that the 'norm'.
You can highlight to drawing view, and then set the hide/show layers
attributes there.
Christopher Gosnell
TRIGON INC.
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
PH: 724.941.5540
FX: 724.941.8322
www.fpdinc.com
mlocascio
(To:bmozley)
Brad,
It's not a matter of the "creation" of the layer. The issue is in what level
you are collecting your entities for that layer.
You have selection options in your layering process that will allow you to
place specific entities on SPECIFIC VIEWS. If you know the name of your view
you can select that from your layer options. Then you either add or remove
layer entities according to your preference in that view.
Michael P. Locascio
