Hi Friends, I hope you guys only can help me to get a solution. I created a dual dimension in a drawing sheet,Pro-E W3.0. I need Primary dimension(MM) should have 2 decimal places and the secondary dimension(Inches) should have 3 decimal places. If i try to give decimal places as 3 by selecting the dimension, im getting the change in both the primary and secondary dimensions. Please help me, thanks in advance.. Regards, Balaji. M
