So, Pro/E gurus, I know there has to be a way around this, but I'm running into part regeneration failures (and ending up in Resolve Mode). Unfortunately I haven't yet found a suitable solution.
The part is simple; a slender piece of extruded stock with holes down its length. The FT variants are length of the piece and the resulting hole pattern. So far, pretty easy.The problem is the holes themselves. Currently there are only two different types of holes. These also vary from instance to instance. Some instances have a plain through hole with a chamfer on one side; other instances have a pattern of tapped (thru) holes. For any given size of part, the pattern dimensions (hole locations) are always the same; only the selection of hole styles varies. So how do I generate TWO different hole features in the same exact locations, and then put that information into a FT. (At the risk of over-describing the problem; Instance 1 is a 3 inch long part with 3 Through Holes; Instance 2 is a 3 inch long part with3 Tapped Holes. Hole LOCATIONS are identical.) The part SEEMS to be failing with the addition of the chamfer to the plain thru holes, if that helps at all.
My gut tells me this should be pretty easy, but I just don't seem to be finding a suitable solution. In your responses, consider that I am pretty new to Pro/E.
