Parameters interface size
ptc-1703378
Everyone,
Is there a way control the size of the parameter interface. I thought at one time it could be done through menu.def. ????????????
TIA,
Ben
mbraaten
6-Contributor
(To:ptc-1703378)
No. But you could write a mapkey using a trail_file that expands the window.
Mike Braaten
Can you repeat the part after "Listen very carefully"?
